Ok, I have downloaded this utility (vfapi), but I cannot get it to convert my .d2v to an .avi file.
It goes through all of the motions, but the file is not there after I convert it.
Yes, I ran the command set up file first.
Does anyone know what my problem may be?
Could you possibly enlighten me on ANY other ways to convert .d2v to .avi??
Thanks in advance for any help!
hp
Assuming you installed the VFAPI codec correctly, open dvd2avi, select help and check VFAPI plugin.
2. Have a look to your dvd2avi directory. There must be a DVD2AVI.VFP file. Someone told me, that he downloaded a dvd2avi version without that file. Maybe this is your problem too. -
This also happened to me after I upgraded to TMPGEnc 12j. I haven't made any concrete connections between upgrades and VFAPI installations, as I haven't had time. So far I haven't had a d2v file crash on me (which prompted my use of convertor software in the first place) so I havent had incentive to look into it.
My VFAPI converter seems to work OK but Virtualdub can't load the file afterwards. "Cannot determine filetype.." it says. Something has happened because it worked fine a couple of weeks ago. Any suggestions?
Now it works again. Seems that there are two versions of VFAPI packages out there. The one that unpacks all files in the same folder works. ..or is it something else?
D2V Creator in MeGUI
By mysteryman26 in forum Newbie / General discussionsReplies: 2Last Post: 17th Mar 2011, 05:40 -
What does this .d2v parse tell me?
By fatcharlie in forum Newbie / General discussionsReplies: 54Last Post: 10th Mar 2011, 17:13 -
Syncing audio with d2v
By Norio in forum Video ConversionReplies: 8Last Post: 23rd May 2010, 01:07 -
meGUI .VOB to .D2V Conversion - Audio Demuxing Speed?
By quicksilverg4 in forum DVD RippingReplies: 0Last Post: 29th Dec 2007, 17:04 -
splitting *.d2v into separate files for xvid conversion
By greenbag in forum Video ConversionReplies: 15Last Post: 22nd Sep 2007, 17:14
