Hi,
Is it possible to use TMPGEnc to resize the DVD to fit on one DVD and still keep the 6ch sound (Dolby or DTS)? I would like to use this over DVD2One because is sounds like with the latter you can't set the low end bitrate to what you want.
Thanks,
Rick
I have it on good advice that no, TMPGEnc doesn't support this feature
That's why I use dvd2one.
W.tgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have. -
Yes, demux the audio first using something like VDub and save it. Encode your video with TMPEGEnc the remux the audio back in using the MPEG tools in TMPEGEnc. A little more work but not too bad. With that said the DVD2One solution is a good one.
MP4/AAC -> XVid/AC3 6ch
By brugi in forum Newbie / General discussionsReplies: 16Last Post: 20th Aug 2014, 21:43 -
6CH DTS Channel Order?
By maxeemo in forum AudioReplies: 4Last Post: 14th Apr 2011, 16:58 -
Video Conversio Keeping Surround Sound Audio........
By themediaman in forum Video ConversionReplies: 4Last Post: 18th Nov 2010, 05:31 -
Problems with sound on 6ch
By pixiesoft in forum Authoring (Blu-ray)Replies: 3Last Post: 5th Apr 2010, 07:12 -
Increasing voices in 6ch audio
By silverwolf0 in forum Newbie / General discussionsReplies: 1Last Post: 23rd Aug 2007, 16:21
