I've got a 4.48GB MPG file, nicely encoded in DVD format.
Now all I want to do, is take this MPG file, and put it on a DVD-R that would hopefully be compatible in as many standalone players as possible.
Any ideas folks?
Flip
ffmpegX should do it: Tools > open mpg in the small "video" field > "postprocess" (disable "mux") > "author as DVD" (disable other author options) > Go! (if it doesn't fit then reencode it at lower bitrate).
That's not going to fit on DVD-R. You need to keep them under 4.37 GB. You could try demuxing the mpg, reencoding the audio at a lower bitrate and remuxing.
I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté." -
Ok, i followed Majors directions, and it produced the VIDEO_TS and AUDIO_TS folders. Great, so I burned them like I have done manytimes before.
But the result is disk that says UDF on it, what the heck is that? DVD player pops up but will not play it.EarlyGrace
streaming of h.264 encoded file
By asifjanjua88 in forum ProgrammingReplies: 4Last Post: 10th Mar 2012, 03:41 -
Virtualdub opening H264 encoded file
By tvbear in forum EditingReplies: 0Last Post: 26th Dec 2011, 06:22 -
ConvertXToDVD Subtitle encoded file?
By theamilien in forum SubtitleReplies: 0Last Post: 16th Aug 2010, 04:07 -
x264 encoded mkv/mp4 transcode to xvid encoded avi
By graysky in forum Video ConversionReplies: 4Last Post: 9th Aug 2008, 18:55 -
Spliting large mpg file into clips and saving each clip as a mpg file ?
By denise4gb in forum EditingReplies: 1Last Post: 6th May 2007, 17:52
