  1. Hi!
    I have version 2.02.31.119
    I was wondering if newer versions give better DVD pictures that would warrant me making the upgrade?
    Thanks,
    Rick
    Mar 2001
    Antwerp - Belgium (Europe
    I use version 2.57+, though there are a few newer versions it's not worth for upgrading. Results are all nearly the same.
    And in your case - if you're happy with your results, why should you upgrade?
    Dec 2002
    Michigan, USA
    The very latest version knocks the audio and video out of synch when doing the "vcd header trick". I had to go back to the previous version.
