Hi,
I am using DVDit 2.5 to try to make a DVD.
My mpeg file is about 1.5 hours long and capture at 5000kps. I did all the necessary and try to build DVD folder. I have choose to convert the audio to Dolby Digital at 128kps. After all the demuxing, transcoding and then I think when DVDit try to multiplex it, it gives me an error message "VTS greater than PTS" and then fail to build the folder.
I have successfully to do that when I test it with file that is say 15min or 30min but when it comes to long movie it did not go.
Anyone can help or explain what the error message or what should I do to get rid of the error would be great.
Results 1 to 1 of 1
Error Message when selecting a movie in VTS
By bobarnett in forum SVCD2DVD & VOB2MPGReplies: 0Last Post: 4th Sep 2011, 15:08 -
Runtime Error playing back ripped DVD folder
By oshanruiz in forum DVD RippingReplies: 0Last Post: 14th Jul 2011, 11:15 -
Creating DVD-s from VTS folder files
By 1234567 in forum Authoring (DVD)Replies: 6Last Post: 16th Feb 2009, 12:40 -
FAVC - Error (Fix VTS Sectors failed!)
By tim_ver in forum Newbie / General discussionsReplies: 1Last Post: 31st Jan 2009, 01:16 -
Error in Build 5000
By ttyner in forum SVCD2DVD & VOB2MPGReplies: 13Last Post: 9th Dec 2008, 13:25
