Ive been trying to recover a Xvid.ac3 without luck. Ive loaded into Vdub, reconstructed the missing blocks, and made the rekeying. This didnīt work, despite the fact that vdub says that theres no bad frames in the vid. Then, I tried to use divfix, I striped the index, and rebuild it. No luck. Both CCE and Tmpeng crash in the beginning of the SVCD conversion.
Data of the video after my attempts of correction:
Frame: 640x352 25fps
#frames (time) 63372(42:14)
Decompressor Xvid Mpeg4
Number of keys frames 0
Total key frame size (no key frames)
why not try saving out the uncompressed audio as ac3 and then change to wave with headac3e and then change the compression of the video stream to 4.12. I use this method and it normally works and you don't lose much quality on the change of compression due to the high quality of the xvid file!
Hope this helps
Tom
The Best Way to recover old VHS tapes
By klode in forum RestorationReplies: 15Last Post: 19th Apr 2011, 08:39 -
How to recover a DVD-R
By darkcyber in forum Newbie / General discussionsReplies: 3Last Post: 21st Jan 2010, 11:48 -
Recover MP4-files
By Mållgan in forum Newbie / General discussionsReplies: 5Last Post: 18th Jun 2009, 14:38 -
How much can par2 recover?
By macamba in forum Newbie / General discussionsReplies: 5Last Post: 21st Feb 2009, 12:16 -
Need to recover deleted files
By alegator in forum ComputerReplies: 5Last Post: 16th Apr 2008, 23:38
