after downloading a film i put it to vcd and played it on my dvd player and it played upside down but playing it on my computer it was all ok can any one help or give me some advise![]()
if we dont know what you used ,and how
we cant offer you much help.
try virtual dub flip filters, and frameserve to tmpeg for encoding to vcd.HELL AINT A BAD PLACE TO BE -
Better yet, do a SEARCH in the forums and you will find your answer.....
Most likely it will be a codec problem. Try uninstalling your codecs and reinstall the Nimo Codec Pack.
Or, use the VirtualDub Flip Fliter as Heavensent suggested. If you have issues with VirtualDub/TMPGEnc, look at the guides!! They really are VERY good!!!
