In your fine opinions...what are the most imp pieces for the capturing and then authoring process?
I have:
AMD XP 1800 (1.5 MHZ)
512 DDR 333 RAM
creative audigy card w/ firewire
Nvidia MX400 videocard
Pioneer AO5 DVD burner
am using verbatim DVD-R 2x
Capturing seems to be fine, but authoring can take up to 6-7 hrs
Someone suggested I go to a new system with dual processors??
Cheers,
Jedi27
for capturing a dual system not going to be importaint .. a dedicated high quality capture card is what is importaint (or at least more importaint) .. with a good hardware card - one does not need a fast system , only a good stable system with a good throughput ..
i mean we were capturing full D1 years and years ago w/ 300-400mhz intel systems and never a problem , lot of people still today happly editing away on 300mhz-400mhz old mac systems which are slow as dog breakfast but those systems work great ..
for authoring -- do you mean re-encoding or editing ? for authoring again a speedy system is not that important - i would take a stable system with huge amounts of storage over the fastest system around ..
what a dual system gives you is faster encoding with many encoders such as TMPGenc , main concept, CCE while also letting you do things such as capturing the same time and even burning multiple disks the same time (well i do, but all scsi and firewire rocks also)
All in one converter for x64 systems?
By davidsl_128 in forum Video ConversionReplies: 4Last Post: 7th Feb 2011, 16:29 -
dual-boot systems
By joecass in forum Newbie / General discussionsReplies: 7Last Post: 16th Jan 2011, 21:01 -
Capturing with Pinnacle Studio Ultimate 14 or should use another programme?
By avz10 in forum Capturing and VCRReplies: 10Last Post: 28th Jun 2010, 13:09 -
64 bit op systems
By dblake2 in forum Authoring (DVD)Replies: 5Last Post: 10th Jul 2008, 17:44 -
all in one home theater systems
By CODEWERKX in forum Newbie / General discussionsReplies: 1Last Post: 4th Dec 2007, 12:09
