Has anybody tried this:
Take a PAL DVD. Demultiplex it. Use pulldown.exe on the video stream to force it to 23.976FPS and set the pulldown flags. Use something like GoldWave to timewarp the audio to fit. Then write a DVDR and play it back in PAL60 mode?
What you have then is effectively a 720x576 NTSC Film DVD, which is a totally illegal format but is it likely to work in any PAL DVD players? The aim here to get the quality of PAL but without the pitch shift and speed up.
Dave
Results 1 to 1 of 1
Using NTSC (16:9) and PAL (4:3) sources to restore a film...
By takearushfan in forum RestorationReplies: 61Last Post: 3rd Mar 2012, 16:13 -
How to convert a .ts in PAL format to a .ts NTSC format???
By jwmghf in forum Video ConversionReplies: 4Last Post: 4th Sep 2011, 10:40 -
Add pictures before DVD PAL film (problem)
By saqu in forum Authoring (DVD)Replies: 4Last Post: 15th Nov 2010, 17:17 -
Getting film look on BFF PAL DV video without deinterlacing?
By arminio in forum RestorationReplies: 0Last Post: 17th Sep 2010, 04:21 -
NTSC/PAL but exact film length: How so?
By Anonymous5394 in forum Newbie / General discussionsReplies: 2Last Post: 5th Mar 2010, 12:42
