Hi I use ifoedit to author a dvd but the dvd pauses at around 1hr 19 min and plays out all the remaing subtitles in no time and there are no more subtitles displayed for the rest of the movie.
can any one help me?
Method
rip with smart ripper
re encode with tmpeg using dvdtoavi
demux subs with vob edit
authored wit ifo edit
You might want to give www.dvd2one.com a try it does subtitle's very good I was using DVD2DV-R then you have to fix the sub's take's a long time. Also www.dvdxcopy.com is good
I need IFOedit for Mac
By bryceguy in forum MacReplies: 7Last Post: 14th Dec 2011, 11:45 -
ifoedit question
By J. Baker in forum Newbie / General discussionsReplies: 3Last Post: 17th Sep 2007, 03:10 -
IFOedit question...
By Djard in forum Newbie / General discussionsReplies: 6Last Post: 4th Aug 2007, 00:42 -
adding CC with ifoedit
By loster in forum Authoring (DVD)Replies: 0Last Post: 9th May 2007, 19:15 -
Subtitles muxed with IFOEDIT are always green and blurry
By Barse in forum SubtitleReplies: 2Last Post: 7th May 2007, 07:50
