Hey,
I have some divx movies which i want to put on a dvd+r so my dvd player can read it. But how do i do this? Do i first have to convert it to svcd or something? Please explain. My goal is to let my dvd player see it as an svcd, but because the dvd is like 6 times the capacity of a normal cd, i thought maybe i can put multiple movies on it, for example 3 movies on 1 dvd+r
I have put 2 DivX movies onto a single DVD-R by resizing and encoding them to MPEG2 using TMPGEnc or CCE. The results have been very good as well.
Tools used:
TMPGEnc or CCE
DVD Maestro
Powerbit for bitrate calcs
I simply convert to 2 separate streams (M2V and MP2) ensuring that the bitrates are set so that each movie only uses 50% of the disk space. I then add them as 2 separate movies into DVD Maestro, add chapter points and make a simple menu for selecting the film I want to watch.
You can do the same thing with 3 movies but the quality will obviously suffer.
Home video 8.4GB on Dual Layer DVDr want to put on 2 4.7gb dvdr ??
By rockonvidtrade in forum Authoring (DVD)Replies: 11Last Post: 19th Oct 2013, 23:25 -
multiple questions here so i'm not sure where to put this
By pmmassacre in forum MacReplies: 10Last Post: 12th Jun 2009, 07:49 -
Taking portions of multiple dvds and put them onto another
By ulremember in forum Authoring (DVD)Replies: 10Last Post: 4th Mar 2009, 18:07 -
Question how to put several dvds on one DVDr
By jimdagys in forum Authoring (DVD)Replies: 7Last Post: 24th Nov 2008, 10:29 -
Can I put multiple video files onto one DVD?
By flameout in forum Authoring (DVD)Replies: 4Last Post: 17th Jul 2007, 15:12
