Hi,
I've been using all versions of ffmpegX since 004d.
Before, with v 004 I could obtain a mp2 file alone, out of a vob file (not ticking any preset and using the audio encode only at the proper rate).
I used this possibility sometimes for later multiplexing.
With v006 this does not work any more.
Also (and I feel it may come from the DVD itself), I recently tried a SVCD (I'm succesful normally) with v006e and it did not work (encoding stopped immediately) whereas the same vob was taken into account by v004k (but with sync problems, even if I'm only working in PAL)
My question : - did the engine mpeg2enc was changed recently or maybe the command lines have been changed in v006 ?
- is there a way in v006 to extract sound only from a vob ? (I mean create a .mp2 ?)
Thx
LG GSA-E60L or GH22NP21 does not burn MCC-004-00 well.
By Vianty in forum DVD & Blu-ray WritersReplies: 4Last Post: 30th Sep 2011, 03:49 -
FFmpeg behaves differently
By vinodkalpaka in forum Newbie / General discussionsReplies: 6Last Post: 17th Aug 2011, 12:14 -
Ripbot behaving strangely
By nikemouse in forum Blu-ray RippingReplies: 3Last Post: 6th Nov 2009, 00:08 -
Pioneer DV-400V won't read Verbatim MCC-004
By unknownsoldierX in forum DVD & Blu-ray PlayersReplies: 0Last Post: 20th Sep 2008, 14:55 -
Extensions (ffmpeg, mencoder, mpeg2enc) what do they mean
By loveformetal1 in forum ffmpegX general discussionReplies: 4Last Post: 18th Jun 2007, 01:30
