i am trying to convert a 2h movie to cvd and fit it on two discs.
so i get the audio with vdub with mp3 compression
then use the bitrate calc to get the right bitrate for 1h on i disc but it says it will take 60h for the half when my last 2h took 20h per half
what is wrong?
Are you applying any filters, these dramatically increase the encode time. Also the setting you use for motion search precision will have an effect on the encode times.
i use no filters and very slow motion search precsion but i always use that this 1 just takes longer
Anyone mirrored or saved OGT/CVD subbed test images?
By zinchronized in forum Newbie / General discussionsReplies: 5Last Post: 11th Aug 2010, 22:46 -
Looking for test SVCD images with CVD/OGT subs
By zinchronized in forum Authoring (VCD/SVCD)Replies: 0Last Post: 11th Aug 2010, 07:55 -
Frame rate conversion for NTSC to PAL conversion?
By Trellis in forum EditingReplies: 33Last Post: 27th Jul 2010, 09:55 -
Video8 Conversion: Best trade-off for digital conversion ?
By ghl1 in forum Video ConversionReplies: 12Last Post: 6th Mar 2010, 18:36 -
Quality loss VHS > CVD, DVD
By rglmrj in forum Video ConversionReplies: 15Last Post: 1st Jun 2007, 12:13
