I have a AVI in v5 DivX format, that when you look in Gspot or AVICodec all looks OK (See attached screen images), but when you play back in WMP you get only audio?
When you open the AVI in VDub, you get an image, but when you play the AVI, the image doesn't change (i.e. it remains as a still of the first slide). If you stop playback, and move the slider bar manually, the start playback, you get a different still image.
Opening the AVI in CCE gives a blank green image.
I've tried reinstalling DivX 5.0.2 Pro, without any change.
Anyone give me any clues please ?
Try open up your movie with other player like ZoomPlayer which is very good.
I have no clue if this works if the movie still not gonna play using another player,try then using the AviC which comes along with the xvid codec and change the FourCC to another like xvid or something -
Bingo! Thanks for your help crack_man!
Changed it to xvid and it now works
Weird (to me) subtitle problem
By alvabass in forum SubtitleReplies: 3Last Post: 31st Dec 2011, 14:50 -
DVDStyler weird problem
By xeroblast in forum Authoring (DVD)Replies: 0Last Post: 8th Sep 2011, 02:37 -
weird computer problem
By lordhutt in forum ComputerReplies: 5Last Post: 1st Dec 2009, 16:45 -
Weird problem with ----- video for windows/codec/playing/or i don't know
By RYGER in forum Software PlayingReplies: 11Last Post: 7th Sep 2008, 21:03 -
Weird I don't have XviD or DivX codec installed but I can see Xvid movies
By Talayero in forum Software PlayingReplies: 4Last Post: 5th Jun 2008, 12:47
