I have a problem... when i try to encode my DVD-rip to mpg format, so i can make a VCD, it can't do it!! Very annoying... Plz help me(im using nero-burner, but have also tried TMPGEnc-0.11.27.111)
Have you tried the latest guide ? i can practicly say 99% that if you follow it step by step you can't fail! it's nearly fool proof!
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
Perhaps, he isn't using DVD2AVI inbetween steps (which also suggests that he hasn't read the guide) to get his D2V and WAV files.
I am having similar problems. I get a video stream sometimes but no sound using TMP. any ideas
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
Well, this is not a very detailed request. What are you trying to convert? -
I got the same prob sometimes but not always
I get the Video but not the Audio
Converting DivX too mpeg (VCD PAL) using TMPGEN
<font size=-1>[ This Message was edited by: NICKA 1 on 2001-09-05 13:06:35 ]</font> -
Usually DivX video contain MP3 audio. Did you convert the .mp3 to wav before you use the audio in TMPG?
Rip VCD to ISO without converting
By cynikalhedonist in forum Authoring (VCD/SVCD)Replies: 9Last Post: 11th Mar 2011, 12:50 -
Rip audio from VCD
By miamicanes in forum AudioReplies: 9Last Post: 4th Aug 2010, 08:04 -
How to rip a copy protected VCD and then burn to a CD
By c1steady in forum Authoring (VCD/SVCD)Replies: 4Last Post: 17th Jul 2009, 14:11 -
By c1steady in forum Newbie / General discussionsReplies: 3Last Post: 17th Jul 2009, 06:40 -
help rip vcd
By Mjzchild in forum Authoring (VCD/SVCD)Replies: 1Last Post: 28th Jun 2007, 02:39
