After capturing and encoding a whole series of videos to MPEG 1 video with dvd audio(48KHZ) I authored and burned it using Ulead Moviefactory. Most or all of the episodes, the audio is out of sync when it is played off the burned dvd. I tested the non-burned mpeg files on the computer and they play fine. The episodes start off synced but then gradually get out of sync. Any suggestions or a recommendation for other dvd authoring programs that can accept mpeg 1 files other than Spruce. Thanks
I tried burning it on memorex dvd-r and maxell dvd-rw, both have the same results.
Mpeg-1 is an accepted format for DVD, so there is no need to re-encode. However, the resolution must be 352x480 or 352x240 or 720x480. If it's not, any authoring program will re-encode to a compliant format.
I haven't tried it but I think that you can set the options, so that Ulead DMF 2.0 doesn't re-encode your compliant mpeg files. The re-encoding of the files might be creating an out of sync problem. TMPGEnc does a better job of encoding or re-encoding files. I have had out of sync problems when using the Ulead DMF encoder (which uses the Ligos encoder).
PS Here are the DVD specs:
http://www.disctronics.co.uk/technology/dvdvideo/dvdvid_videnc.htm -
Its 352x240, i suspect the problem is when Ulead multiplexes the video, is there anyway to stop this?
Ulead DVD MovieFactory 6 Plus Menu Option Question
By SCDVD in forum Authoring (DVD)Replies: 3Last Post: 26th Jan 2009, 14:42 -
Ulead DVD Moviefactory 6 Plus (trying to get to grips after UDVDWorkshop2)
By dvdfever in forum Authoring (DVD)Replies: 3Last Post: 3rd Jan 2009, 21:01 -
Joining in Ulead DVD MovieFactory - does it lead to worse quality?
By rosbif08 in forum EditingReplies: 2Last Post: 6th Aug 2008, 22:32 -
Ulead DVD Moviefactory 5
By Flying Doctor in forum Authoring (DVD)Replies: 2Last Post: 2nd Aug 2007, 11:43 -
Questions about Ulead DVD MovieFactory 6
By cheeseandcrackers in forum Authoring (DVD)Replies: 5Last Post: 18th Jun 2007, 11:46
