I captured miniDV via firewire using Ulead Video Caputure 6.5 and got an output
with these specs: AVI 150MB 43sec 720x480 (DV Video Decoder setting in WMP is set
at FULL quality). When I playback this file, objects in motion get stripe lines on
them, mostly noticeble when they move and full screen playback. If I switch to HALF
quality in DV Video Decoder setting of WMP, it becomes 360x240 and more blurry and
these stripes cannot be seen. What makes them happen? Also, captures look okay at
100% zoom in WMP, but if I double it or make it full screen, they become blurry. Is
it normal, or will it look okay on TV if I'll burn it on DVD-R? Does firewire card
plays any role in the quality of video it takes from camcoder? Is Ulead MSPro 6.5
is one of the best at capturing from miniDV? Thank you in advance for any hints or
suggestions on any of these newbie questions.
P.S. My goal is the get the best possible quality out of DV (no matter how much
space it takes, I will upgrade hard drive if I'll see success) to put on 2hr DVD-R.
P4 2.26Ghz on Asus P4S533
256MB PC3000CL2 DDR
ATI Radeon 7200 64MB SDR
Sound Blaster Live! MP3+
2x WD200BB
HP 9100i
Sony MiniDV TRV27
Adaptec Firewire
(waiting for success of good looking video files from DV to get DVR-A05)
You are probably seing interlacing. You might also notice certain DV artifacts. But they will not show up on your TV.
miniDV format is interelaced. You'll see strip lines. WMP in half duplex will get eliminate half of the resolution (remove every 2 lines) thus eliminate the interlace effect but blur up the video a bit. Unless you get one of those progressive scan cams. The interlace lines will go away on TV sets as suggested earlier.
https://www.videohelp.com/forum/viewtopic.php?t=137859&highlight=
it took me almost 2 years to realize that these won't show up on tv. i suck.
any FW card is fine.
I use DVIO, i used to use Premiere and DVIO is just as good and tiny tiny tiny little app (won't tax resources like premiere etc.)
the blur is normal over 100%
ZZ
High Quality Capturing with Little Frame Loss in VirtualDub
By monsoon01 in forum User guidesReplies: 65Last Post: 18th May 2013, 23:33 -
capturing high-quality streams
By topquark in forum Newbie / General discussionsReplies: 0Last Post: 24th Apr 2010, 02:12 -
lower low quality online tv how to high quality :( :x
By gorry563 in forum Video Streaming DownloadingReplies: 1Last Post: 22nd Feb 2009, 07:56 -
&fmt=18 does not give the same quality as playing by "high quality
By arminio in forum Video Streaming DownloadingReplies: 2Last Post: 9th Feb 2009, 19:33 -
Digitizing High Def miniDV tapes
By mark25s in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 19th Jun 2007, 22:09
