Does anyone know if there is a tool(hehe, i said tool) to extract the chapter lists from a dvd into a plain text file. I am trying to convert The X-Files Season 1,2 and 3 boxed sets into SVCD(1 episode per SVCD). I have switched to DVD2SVCD which has simplified everything except for preserving the original chapter entries. Currently i am manually creating XML files for VCDImager and it is getting tedious doing each episode.
There's a proggy called "ChapterXtractor". You can download it from doom9's site: http://www.doom9.net
All you need is to load up the relevant IFO with this proggy.
Regards.
Michael Tam
w: Morsels of Evidence -
Smartripper 2.34 creates an INFO.txt file, that includes a chapter list (by frame numbers).
Thanks for the speedy replies. ChapterXtractor is just what i need. And thx to Truman for pointing out the useful info about Smartripper as i do occasionally use that for when DVD2SVCD just doesn't like certain discs.
TTFN
IE8 - unable to view drop down lists. Help!!
By thegeeman in forum ComputerReplies: 4Last Post: 18th Aug 2010, 10:01 -
Extracting DVD chapter names from a DVD
By indijay in forum DVD RippingReplies: 3Last Post: 24th May 2010, 15:56 -
Codec drop-down lists?
By terrypin in forum Newbie / General discussionsReplies: 4Last Post: 11th Jun 2009, 07:34 -
How do you get Explorer file lists to print?
By ahhaa in forum ComputerReplies: 13Last Post: 28th Jan 2008, 10:34
