To convert a 640x272, 25fps avi to an svcd (using the header trick), do I have to change the frame rate to 23.976? Should I resize it to 720x480, or should I leave both as is? I'm using TMPGEnc, with '3:2 pulldown' unchecked & 'do not frame rate conversion' unchecked.
Thanks,
Chris
You've started with a PAL film.
So conversion depends on where u are chris, and the capability of the hardware u use. I live in UK and have a dvd player that happily plays ntsc films, but tv will not accept the input so only get shit b/w picture, I have to stick with pal format . What output u looking for? svcd pal or svcd ntsc? if your outside Europe it will probably be ntsc, but if your in Europe then you might not need to convert at all (25fps = pal)you know it's the anti-Midas touch when all you touch goes to shit.............. -
U might want to use the TMPGenc wizard unless your sorting the bitrate to fit a long film on one cd. for svcd it will end up 480*480 at 29.97fps for ntsc (352*240 for vcd) . the res of 720*480 is for ntsc dvd films, not for svcds. The TmpGenc wizard will sort it automatically though. Iv'e done loads of conversions the other way, and have needed to do framerate conversion (therefore leaving do not do framerate conversion unchecked)
Dunno what kit you've got, but I have the same problem. My player allows you to choose the output format (SVHS, RGB and something else that I can't remember right now). Selecting RGB output cures the crappy B&W picture.Originally Posted by narked
Of PAL DVDs, .avi files, and frame rates
By AlphaCat in forum Authoring (DVD)Replies: 4Last Post: 30th Jan 2012, 09:23 -
Newbie question about frame rates.
By MrTorso in forum Video ConversionReplies: 4Last Post: 13th Jul 2011, 23:49 -
Editing and rendering with multiple frame rates?
By vid83 in forum EditingReplies: 12Last Post: 2nd Mar 2011, 04:20 -
Virtuadub shows two different frame rates ?
By vodmare in forum Video ConversionReplies: 8Last Post: 12th May 2008, 19:47 -
Encoding in Virtualdub: Do you have to worry about frame rates?
By FallenAngelII in forum Newbie / General discussionsReplies: 28Last Post: 7th May 2007, 12:15
