Hello,
I've been able to seamlessly create d2v project files in the past. This time, my preview in DVD2AVI works fine: shows details on Frame Type, Coded#, etc in the Statitics Window. But, when I save the project (F4), it doesn't appear to be processing it right... no details in Frame Type, etc. Its all blank.
I tried to open the project file in TmpgEnc to encode it but it gives an error "file not supported". The generated .Wav file generated from DVD2AVI plays ok.
Please help me. I'm at a complete loss as to why this wouldn't work. Any suggestions or alternate methods are welcome. Anything !!!
Thanks !
download and install the vfapi plug in for tmpgenc to the tmpgenc folder then reboot
Correct AR(aspect ratio) on dvd2avi conversion (16:9 vs 1.85:1)
By Visual-Artist27 in forum DVD RippingReplies: 10Last Post: 19th Aug 2010, 23:11 -
DVD2AVI/DGIndex Aspect Ratio Problem (Long/Stretched Faces, etc)
By munkeyman in forum DVD RippingReplies: 7Last Post: 19th Feb 2010, 09:47 -
How to frameserve (dvd2avi / VirtualDub / Avisynth / VFAPI)
By Truman in forum User guidesReplies: 32Last Post: 20th Nov 2007, 08:38
