i'm trying to burn with an external hp dvd writer, sonic mydvd, and right before it's about to start burning it says:
"Cannot perform operation, Pins are not connected. error xxxx" (obviously there are numbers where after the word error that i did not catch).
Please help!
thank you ahead of time!
its a error code w/ direct show problem indicated (almost always Microsoft DirectX 8.1 (C++))
VFW_E_NOT_CONNECTED 0x80040209 521
means that a file is not being read (rendered to windows) properly
other than that i have no idea how to fix or why its envoked on burning .
try upgrading/downgrading DirectX ? or reinstalling some software maybe -
the above info in on the msdn web site (i didnt know it off the top of my head)
maybe there you can find more info
http://msdn.microsoft.com/library/default.asp?url=/library/en-us/dx8_c/directx_cpp/htm...ccesscodes.asp -
what are PINS and how can i connect them?
i've tried all sorts of different files, so it's not the files.. -
pins as in graphedit type of pins ... its a expression of a connection in software
I still have not figured out my "pins are not connected" error.
It seems to only happen when I capture an AVI with no compression.
It happened with DX8.1, and it happens with DX9. I have an AIW9700 with the newest drivers, and my capture drive is a dedicated RAID 0.
If anyone has any ideas, please help..
thanks
PRO
what does this mean 'pins in the graph' RE: FLV file.
By talx in forum Newbie / General discussionsReplies: 2Last Post: 20th Nov 2011, 12:26 -
How to disable MPC "could not render some of the pins in the graph" warnng?
By SignedupGuest in forum Newbie / General discussionsReplies: 4Last Post: 6th Feb 2011, 23:50 -
Media Player Classic could not render some of the pins...
By museamused in forum Software PlayingReplies: 0Last Post: 10th Dec 2010, 16:44 -
There is no common media types between these pins.
By Facelyss in forum Newbie / General discussionsReplies: 6Last Post: 21st Apr 2010, 23:29
