  1. Does anyone know if you can make your own CDV´s somehow?
    I know they only fit 5 min and aren´t that good but it would be kind of fun to try it.
    Jul 2001
    (double post)
    <font size=-1>[ This Message was edited by: Feslmogh on 2001-09-04 07:58:41 ]</font>
    Jul 2001
    You're out of luck on that one becuase..
    1. Laserdiscs are expensive to produce than DVD and VCDs
    2. Unless you have a Laserdisc player, you won't be able to play it on other players. Laserdiscs are analog and DVD's are digital.
  4. No luck I am afraid.
    The mini laserdisc CDVideo format is completely different to VideoCD. CDVideo is an analogue video format coupled with digital audio whereas VCD is completely digital.
    As Feslmogh says even if you could you would NOT be able to play the CDVideo disc on any VCD or DVD player only on laserdisc players.
