Hey Guys. I'm using Adobe Premiere 6 to capture my Mini DV home videos. Uptill now, I was converting these home videos into VCDs. However, I just bought a Pioneer A05 DVD burner and would like to make DVDs of my home videos. How can I do this using Adobe Premiere?
So, once I've edited my videos in Adobe premiere, how can I convert it to a DVD.
Would you please tell me what the process is and what software I need as well?
Thanks a tonne.
B.
I used Ulead DVD Workshop. I got the best result when I edited my videos first and then save as raw AVI. Instead of converting using TMPGEnc, I just drag the AVI directly in Ulead DVD Workshop (create menus, music, motion, etc) and let it compress the files into the DVD folders. I then used Prassi Primo (Nero has issues) to burn to a DVD.
Ulead DVD Workshop - trial version available for free and easiest to use. -
Hello Petco. Thanks so much for your input. I will download the demo for Ulead DVD Workshop and give it a shot. In the mean time, are there any settings or any tips that you could give me for?
So far, I have
1) Save the edited video as RAW avi.
HOW DO I DO THIS?
To everyone else:
ANY OTHER SOFTWARE THAT YOU LIKE TO USE OR METHODS YOU HAVE?
thanks a lot in advance.
B. -
Sorry about that last incomplete post. I hit tab and enter thinking I was in Word! Sorry. Here's what I meant to say!
So far, I have
HOW DO I DO THIS?
To everyone else:
B. -
You may want to try less expensive solutions such as Ulead DVD Movie Factory 2.0 or Dazzle DVD complete. You are better off encoding to mpeg with TMPGEnc.
