Ok, heres my problem. I own a Panasonic HS2 DVD-Recorder. I captured a PPV event that I want to put on DVD. I copied the VRO files one by one (total of 3) to DVD-RAM and copies them to my computer. I then used Vobedit and IFOedit to prepare the VOBs to create the IFO files. When I try putting the end result into DVD2One, it hangs, no errors or anything. But it doesnt encode them either.
So how can I get these various VOB (VRO files renamed) in a structured format that DVD2One can understand and transcode? Just getting tired of throwing 3 dvdrs for each PPV I record.
If you get VRO then you are using DVD RAM correct?
I just copy the entire DVD-Ram to my HD then rename the VRO to mpg and use tmpgenc there is a option under mpg tools so no encoding is done. There is thread on this site with all the details, search on DVD Ram or E30/HS2 to find it.
BUP, IFO, VRO -> MPEG, needed for video editing?
By soccerdude21490 in forum Video ConversionReplies: 12Last Post: 20th Nov 2009, 12:31 -
Vro to Vob conversion?
By marty mcfly in forum Video ConversionReplies: 6Last Post: 30th Oct 2008, 22:16 -
Connecting Freeview to Panasonic DMR-HS2 Advice Required!
By wilberfork in forum DVD & Blu-ray RecordersReplies: 2Last Post: 21st Aug 2008, 08:23 -
VRO o VOB
By natty in forum Newbie / General discussionsReplies: 5Last Post: 27th Oct 2007, 15:38 -
4 separate IFO files > one IFO to govern the full .VOB video
By Salva Veritate in forum EditingReplies: 4Last Post: 20th Aug 2007, 14:38
