  1. hello
    i have a avi with 23.976 fpb, i uesd virtualdub 2 convert the avi 2 25 fpb
    and the audio i use with cooledit to resample in 95.904%
    to sync audio with video.
    but i notice that the sync is not that good, and i need
    to enter a delay in the sound, with thempg.
    (i enter about 80 msec to sync the sound/avi)
    but the probem is that i lose some sound in the end and i have frame
    with no sound there.
    how can i fix that ???
    do i need to enter a difrent prescent in cooledit ??
    or i can cut from the strat some frame to sync without give a delay ??
    but i need 2 know how much frames i have in 80 msec ???
    hope u know what 2 do...
  2. Banned
    Jun 2001
    UK
    TTT ? cut a little from the end of the AVI before you do anything.
    See if this helps
    KingJohns Guide AVI 23.976fps to 25fps
  3. i found the problem, but i need some help.
    i found that when i sync the audio/avi with thempg (i put a delay of 80 msec) i lose about 5276 frame with audio, thats a lot !!!!
    i also found that the audio is not complete, it's cut in the end.
    so, is there a way 2 fix that or i need 2 do every thing from the begining ??
    bwt. i not read your guide kingjohn, but i'm going 2
    10x.
