there is something wrong when i try to watch a couple of movies i downloaded. when ever i try to open up the file in windows media player or real one or anything, the picture shows up but it keeps on blinking. it never did this before, can someone help me.
yes, you are using the wrong codec. download the proper one and everything will work fine.
i dont think thats it because i have installed the XviD codec atleast 4 times now.
Use Gspot (tools section) on your files, it will tell you what codecs are required and if they're installed.
"Art is making something out of nothing and selling it." - Frank Zappa -
Go to the Tools section, over there <<<<<<<.
Find and download Gspot under "other useful tools." Install it, run it, load your movie into it, read the results! It tells you what codecs were used in your movie and if you have them installed on your system."Art is making something out of nothing and selling it." - Frank Zappa
