Can anyone tell me if there is an advantage capturing with I frames only in MMC 6.3 for MPEG1 OR MPEG2? What are the advantages or disadvantages. I know that there are also options for capturing for single field or both fields, what are the advantages and disadvantages.
I frames are like keyframes, all the picture information for a frame is stored in that frame. Simplifying somewhat, P frames and B frames store predicted motion and the difference between frames. So theoretically, capturing with only I frames will result in better quality. However, I frames can only take advantage of picture compression similar to jpeg, so captured file sizes will be much much larger.
The big advantage of I-frames only is that you can edit the file as an AVI file, frame accurate without having to decode and re-encode the mpeg file. If you want to edit a "normal" mpeg file, the edit point will be something like +/- 7 frames, out of your control, unless you decode and re-encode the mpeg file. But to get good quality with I-frames only, use the maximum bitrate you can record at. Mpeg I-frames is almost like Mjpeg compression.
Hauppauge capturing frames problem
By richiexd in forum Capturing and VCRReplies: 4Last Post: 18th Jan 2012, 22:18 -
capturing avi frames
By Willy5157 in forum Video ConversionReplies: 2Last Post: 8th Jul 2008, 19:22 -
Getting artifacts and dropped frames capturing DV
By CleanRich in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 16Last Post: 1st Nov 2007, 20:54 -
inserted frames without dropped frames in VirtualDub capturing VHS
By whschlebaum in forum Capturing and VCRReplies: 0Last Post: 23rd Aug 2007, 21:59 -
Capturing problem.. Dropping frames..
By azazel_dx in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 13th May 2007, 15:47
