when using DVD2DVDR i see t audio streams one is AC3 (6 Channels)
and 1 DTS (5 channels)
i thought that DTS have better sound and it have only 5 channels...can someone explain to me please?
May I recomend some light reading.
The answer to your question partially depends on your playback system and resonal preferance.
http://liquidtheater.com/editorials/50 -
who ever wrote that - doesn't know exactly what they are talking about ....
/me Dolby and THX certified and also DTS engineer/mixer -
so if im backing up my dvd with dvd2one and i only want to choose one audio setup so that my video bitrate is higher which one should i choose to play on my sony surround sound hookup with the subwoofer and everything?
DTS actually usually does sound better than Dolby Digital, b/c DTS allows for a higher bitrate, and therefor better sounding audio. Whether or not it's an actual audible difference depends a lot on the viewer/listener.
Also, don't be fooled that b/c one stream has more channels, it will sound better. The sound 'quality' will be the same b/w DTS (5.1) and DTS-ES (6.1), however, if you have a 6 channel receiver, and the proper speaker setup.. 6.1 offers much better sound placement, the actual quality will be the same though.
hope that clears it up for you. -
Not having used DVD2DVDR I don't know how this program works so forgive my ignorance.
Assuming DVD2DVDR will author and burn the DVD with only the DTS track then this will probably give you the best sound, however, to be fully compatible with the DVD standard you must have an AC3 track on the disc.
DTS or AC3
By Bazza-61 in forum AudioReplies: 14Last Post: 30th Sep 2010, 21:28 -
AC3 5.1 to DTS 5.1
By Benjy in forum AudioReplies: 3Last Post: 18th May 2010, 07:27 -
DTS to ac3
By Han Solo1 in forum Newbie / General discussionsReplies: 1Last Post: 29th Apr 2010, 13:24 -
Reauther dvd with pcm & dts to ac3 & dts
By djblade in forum Authoring (DVD)Replies: 9Last Post: 16th Feb 2010, 09:40 -
DTS vs AC3
By Mrsash in forum Newbie / General discussionsReplies: 9Last Post: 29th Jul 2007, 11:16
