  1. How do I create and host an FTP on my computer? Do I need to pay anything, do I need permission from my internet provider, etc? Any information is appreciated. Please be as complete as possible. Thank you for your time.
  2. No Longer Mod tgpo's Avatar
    Feb 2002
    The South Side
    More information is needed. Like your computer profile...which you can put in under your profile.
    If you are on a Mac you can simply click one button to activate ftp sharing. If you are on Windows then you'll have to find a ftp server program.
  3. Sorry about that. I am on a PC, running Windows XP Home. Pentium 4, 256 RAM, 60 GB hard drive... not sure if you need all of that. So, hope that helps.
  4. Член BJ_M's Avatar
    Jul 2002
    Canada
    buy serv-u or get freeware warftp and install it
    see also IP forwarding
    also most isp 's dont allow servers (some do though) - that means on cable or dsl
    doesnt home only allow 10 connections or something ? maybe i am thinking only of IIS
    lots of info on all this on search engines
