RecordNow MAX works fine for me, but I just noticed that when I burn a dvd in RecordNow MAX using default settings it will burn the dvd in
ISO 9660, Joliet, UDF. An orginal DVD movie use only ISO 9660, UDF. So why do RecordNow MAX use Joliet and should I disable joliet?
I have one more question, I use RecordNow MAX ver 4.10 should I upgrade to 4.60? Are there any big differences between this two versions?
Results 1 to 9 of 9
@ Espen, I am not fully certain of exactly what "joliet" is but it has to do with long file names, I believe. It shouldn't matter whether it is diabled or enabled. Test it both ways on an +RW, but I'd be willing to bet that either method will work just fine. As far as keeping 4.10 or upgrading, well if you have NO problems with the version you currently have, then you should probably keep it. I had to have the 4.5 version, because 4.10 doesn't recognize my burner (Sony DRU500a.) I know you wrote that the upgraded version is 4.6, but I think that was a typo on your part, because i'm pretty sure, the latest version is 4.5. Either way, my thoughts are if it isn't broken, don't fix it.
RecordNow DX is version 4.6. RecordNow DX 4.5 comes bundled with the Sony drives and the software has a link to the Japenese site that upgrades it to 4.6
I have Recordnow Max 4.5 and disabled the joliet burned a couple of test DVD-Rs but got errors in Power DVD and my 3 set-top players couldn't recognise them so swithed the joliet back on and so far all my discs work on all my set-top players,even on my XBOX where before using Nero i couldn't get a single disc to work.I will never again use Nero to burn a dvd ......
media 58p Datawrite/Princo, & 67p eproformance..am able to burn both 1xdiscs at 2x on my Pioneer AO4............Spaceman -
Hi all,
Here's a step-by-step RecorNow Max burning Guide. * NOTE: I follow these exact
steps using RecordNow DX v4.6 and it works flawlessly. ( I don't see any difference
bettween the 2 products !)
http://www.highvid.com/DVD/recmax1/rec01.shtml
Good luck !
DevieD -
I'm trying to use Stomp recordnow max 4.5, but i don't know the right settings.
should i chose "track-at-once Closed" or "Track-at-once Not closed"?
i used nero before but i have some problems later playing in xbox and LG standalone players!
i'm trying to find the best settings to be more compatible with most standalone players!
i'm using TDKdvd-rw with Intenso dvd-R!
thanks
bladerunnerpt -
Bladerunnerpt,
Basically use the defaults under Data Disc which are TAO closed and
Joliet blah blah 6 characters blah-> sorry forget exact wording here 8)
I also change the video_ts folder name to all caps VIDEO_TS. Some set top players
are more picky about this than others. See my earlier post above for a guide. -
Originally Posted by DevieDPinnacle Studio 8 and DV home video editing (ver.9 already home)
Anyone here use 3DS MAX?
By Rudyard in forum ComputerReplies: 5Last Post: 25th Jul 2012, 13:53 -
Questions regarding recording settings and compression settings
By so in forum Newbie / General discussionsReplies: 2Last Post: 6th May 2011, 07:45 -
What is max bitrate and max channels supported by PCM audio format?
By Bonie81 in forum Newbie / General discussionsReplies: 10Last Post: 18th May 2010, 23:35 -
how to achieve max quality in fairuse wizard, x264 settings
By llmercll in forum Video ConversionReplies: 21Last Post: 17th Jan 2009, 08:17 -
60 Inch DLP Max 1080i Settings ??
By ofield1 in forum DVB / IPTVReplies: 12Last Post: 29th Feb 2008, 18:54
