Results 1 to 11 of 11
  1. 1) Can one rip and write (a DVD9 movie) to a 9.4GB DVD-R with existing hardware/ software (DVR-105 and, DVD ripping tool, and Nero?)
    2) or is the 9.4GB DVD-R the same as a DVD9 or DVD10. i.e. you cannot write to it with existing equipment.
    May 2001
    DVD-R 9.4 is simply a double sided DVD-R with 4.7GB on each side.
    The answer to your first question, is "Yes", provided you know what you are doing.
  3. So, a 9.4GB DVD-R is a DVD10. right?, which means that you still need to create 2 disc's (using ifoedit) and then write (burn with Nero) to one side and then the other.
    Is my assumption correct?
    May 2001
    Originally Posted by muralin
    touche64:
    yes
    Correct, what he said!
  5. DVD-10
    DVD-10 is a double sided single layer DVD which can fit up to 8.7 computer GB. Video DVD, DVD-R/W and DVD+R/W supports this format.
    DVD-18
    DVD-18 is a double sided dual layer DVD which can fit up to 16 computer GB which some commercial video DVDs are using today (a DVD-18 is basicly four pressed plastic DVD-5s pressed together, they are not burned). Video DVD supports this format but DVD-R/W and DVD+R/W does not support this format.
    DVD-5
    DVD-5 is a single sided single layer DVD that stores up to about 4 700 000 000 bytes and that is 4.38 GigaBytes where 1 kilobyte is 1024 bytes. Video DVD, DVD-R/W and DVD+R/W supports this format. Often referred to as "single sided, single layer". DVDRhelp DVD information
    DVD-9
    DVD-9 is a single sided dual layer DVD which can fit up to 7.95 computer GB which many commercial video DVDs are using today (a DVD-9 is basicly two pressed plastic DVD-5s pressed together, they are not burned). Video DVD supports this format but DVD-R/W and DVD+R/W does not support this format.
    https://www.videohelp.com/glossary#DVD-10
  6. I'm a MEGA Super Moderator Baldrick's Avatar
    <--------------- from our glossary here to left....
    May 2001
    Originally Posted by rhuala2
    DVD-10
    No, it really is 9.4 GB. It is simply two 4.7GB disks bonded together at the factory at the correct thickness. I have used them a couple of times, and they will hold 4.7GB on each side.
    May 2001
    Oh, I guess that we are both "right". I say that it will hold 9,400,000,000 bytes of data. I, like every other creature in the decimal world (universe), say that 1000 is 1000, NOT 1024.
  9. I, like every other creature in the decimal world (universe), say that 1000 is 1000, NOT 1024
    ya but how fast it adds up, I've been asked by a couple people now why the outside of the DVD case says 4.7GB yet it only holds 4.3GB. Sometimes I just mess with them and tell them they got ripped off.
    rhuala
