im useing tmpegenc v2.56 to convert a avi to pal dvd i tryed to use the wizerd but when it starts to encode the little black screen in the middle goes blank and the out put file stys at zero, so i decide not to use the wizerd and just load the dvd template my self it all when well but when it was finished to picture was crap and the mpeg file was only 1.3gig ( the avi file is a screener) so wot i want to no is wot settings to cahnge when i load the dvd template then unlock it wot do i change so i get a better picture
Mark,
describe what you are doing that the TMPGenc wizard doesnt work but loading the templates do....I am confused as to how this can be so. Did you follow the guides on this site step by step ?
https://www.videohelp.com/tmpgencdvd.htm -
The reason for "the little black screen in the middle goes blank " might be that the wiz is using 2-pass VBR. First 50% is dedicated to finding out how to distribute the bits to the frames - no output neither filewise nor picturewise. The mpeg is created during the second pass, and it's not until then that you'll see anything in the preview window.
/Mats -
thanx for the replys i was useing 2-pass VBR. so that is y the out put file stayed the same thanx again
i am haveing the same problem.....except mine is not on 2 pass VBR, im using CBr, and it does the exact same thing.....can someone help me!
Can't access my router's web page to change some settings
By Enowil in forum ComputerReplies: 17Last Post: 10th Jan 2012, 07:57 -
Questions regarding recording settings and compression settings
By so in forum Newbie / General discussionsReplies: 2Last Post: 6th May 2011, 08:45 -
AviDemux 2.5 beta motion precision settings change?
By MilesAhead in forum Video ConversionReplies: 0Last Post: 14th Jun 2009, 16:30 -
Wot the fark is this? I get this popup everytime my cursor touches a video
By jaxxboss in forum ComputerReplies: 6Last Post: 22nd Jun 2008, 10:28 -
change dimensions easily, and encoder settings?
By ChillBill in forum EditingReplies: 3Last Post: 12th Aug 2007, 14:49
