Hey,
I have a problem. I have this dvd that has been made by a standalone recorder on dvd-r. The dvd has about 7 pre-made chapters but I would like to chance these and make my own from the bottom( Merge the existing and create new).
So far I have used DVDDecrypter and have a to VOB files on my harddrive.
Currently I'm using Ulead Moviefactory, but here I can only make new chapters within the existing chapters( can't merge the existing).
Furthermore I'm having another problem because this program apparently doesn't support ac-3 audio. What can I do?
Hope you guys can help me, thanks,
Kenneth
There is a way to create chapters into the movie using IFOEdit. Apparently, while you select the video and audio streams, you can also select an ASCII file with chapter information. I have seen a sample and it is merely a list of chapter times in the format hh:mm
s
I use scenarist to author and it is relatively easy to create chapters. One just positions the timeline pointer to a point and clicks a button. Precice positioning is not possible but exact timing is available by editing the time of the chapter.
What I have not been able to do is navigate through the chapters via a menu.The more I learn, the more I come to realize how little it is I know.
Add chapters (at least) to already made DVD
By tge101 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Apr 2010, 13:16 -
How do you insert chapters into mkvs that you've already made -rtango?
By yoda313 in forum Video ConversionReplies: 2Last Post: 29th Mar 2009, 08:16 -
How can I change titlesets on a dvd to be able to navigate like chapters?
By chello378 in forum Newbie / General discussionsReplies: 3Last Post: 5th May 2008, 23:29 -
How would I change the order in which chapters are played, please?
By c627627 in forum Authoring (DVD)Replies: 123Last Post: 5th Sep 2007, 02:48 -
0.0.9x and pre-Intel
By kwkdy in forum ffmpegX general discussionReplies: 3Last Post: 6th Jun 2007, 08:52
