Can anyone explain why the variable bitrate encoding in the MainConcept encoder takes only one pass to get the required filesize?
Also, does the quality compare well with CCE?
Bottom line is it guesses. It seems to do pretty well, but a multipass would be better and they are working on it (due out soon).
The quality is comperable to TMPEGEnc, which is to say not quite as good as CCE at this point. Single pass to single pass, I would rate it inbetween the two, but a bit closer to TMPEGEnc (although all three are really quite good). -
Multipass is to be supported in release 1.4 and any legitimate 1.X serial will work on a 1.X release. http://www.mainconcept.com/forum/viewtopic.php?t=123
Due to the speed, quality, price and ease its the only thing I'm using now. -
with the correct settings - its look ahead in single pass is excellent ...
excellent encoder ...
which is better Mainconcept MPEG Encoder or H.254 Encoder
By d_unbeliever in forum Newbie / General discussionsReplies: 7Last Post: 4th Aug 2012, 18:14 -
How do I find out if my MPEG vidfile has variable bitrate audio?
By cwb in forum EditingReplies: 5Last Post: 22nd Nov 2010, 08:56 -
What's the best variable bitrate mpeg-2 encoder?
By miggeth in forum Video ConversionReplies: 3Last Post: 25th Jun 2008, 06:01 -
Variable bitrate Mpeg-2
By miggeth in forum Newbie / General discussionsReplies: 5Last Post: 23rd Jun 2008, 07:58 -
Encoding 720p MJPEG file using Mainconcept encoder --> for Streaming vid
By Mysteriouskk in forum Video ConversionReplies: 3Last Post: 25th Nov 2007, 03:39
