    Jan 2003
    In the bath
    I am trying to load an avi into VirtualDub but it keeps giving the message
    "Couldn't locate decompressor for format 'MP42' (Microsoft High_speed MPEG-4 V2)"
    Any help would be welcomed
    Oct 2002
    Slovak Republic
    Try to install Nimo Codec Pack, or MPEG-4 codec. I had the same problem and that was solution of my problem.
  3. codecīs missing
    divx 5 probably
    try to install NIMoPACKcODEC
    select the codecs to install and thatīs done
    Jan 2003
    In the bath
    Where could I get hold of these codecs?
    Cheers
    Dec 2002
    I would definately NOT install Nimo. Install the missing codec only. Nimo can break codecs that are working (sometimes requiring a format/re-install to fix).
    Use G-SPot to identify the missing codec.
    http://www.headbands.com/gspot/
    It's a 'Must Have' program!
    To Be, Or, Not To Be, That, Is The Gazorgan Plan
    Oct 2002
    Slovak Republic
    You can find Nimo Pack in tools section on this web(left bar).
    Jan 2003
    In the bath
    Problem Solved. I downloaded Nimo and installed the Microsoft MPEG-4 codec only which has solved the problem.
    Thanks for your help
