tmpgnc problem says OS reports it cant open cpuinfo.dll a library needed to open it and two other DLL mplvpx.dll and mplapx.dll . I had opened a mpeg2 for resampling to burn to a dvd . It opened then crashed . I reopenend the program and tried to open the mpeg2 again and I keep getting the same error.
I have completely removed and re installed the program twice with no change same error is this a widows problem or a tmpgnc problem
Is there another program I can use to convert files from mpeg1 to mpeg2
ntscdvd
thanks in advance
These don't seem to be standard DLL's. I'd guess they were installed as part of your MPEG-2 player? Did you try re-installing your DVD Player software, or MPEG-2 codec?
Impossible to see the future is. The Dark Side clouds everything...
Need aacenc32.dll & aac.dll for be light
By tofuguy in forum AudioReplies: 5Last Post: 30th Oct 2011, 18:58 -
Problem with libavcodec.dll
By Mitchum22 in forum Newbie / General discussionsReplies: 8Last Post: 31st Mar 2011, 09:15 -
MeGui -> Unable to locate libsndfile-1.dll and FFTW3.DLL
By whatever911 in forum Video ConversionReplies: 0Last Post: 21st Feb 2009, 14:34 -
Avisynth question open failure FF3TdGPU.dll
By duster1234 in forum Video ConversionReplies: 4Last Post: 15th Oct 2008, 07:29 -
Nero 7 installed but no aac.dll or aacenc32.dll?
By AndyD in forum AudioReplies: 5Last Post: 13th Jan 2008, 18:28
