I have a DivX I wanna make a VCD of.
Both TMPGenc and Virtual Dub complains about frame number 4676 and that the audio is'nt possible to decode. I get the "floating decimal point error" in TMPGenc and in Virtual Dub it just stops and says the Audio is broken.
I got around this by encodeing the movie in two parts skipping that frame. But there must be a better way to fix it!
How???
Delete the bad frames !
I use a modified version of Vdub "vdub-mp3-freeze.exe" it scan's the AVI and creates a log file of all the bad frames. You can then delete the bad frames and save a new AVI within a few minuets.
Works very well, if you cant find it email me
How do I debug/extract i-frame p-frame and b-frame?
By jwbrasil2 in forum ProgrammingReplies: 0Last Post: 20th Nov 2011, 12:24 -
Play an MTS file frame by frame, displaying timecode or frame number
By SeánB in forum Software PlayingReplies: 5Last Post: 5th Oct 2010, 16:26 -
how to describe matrix values as if signle value ?
By vhelp in forum ProgrammingReplies: 2Last Post: 27th May 2009, 22:48 -
Advancing/Rewinding Clip Frame by Frame on Windows Movie Maker (Vista)
By ione in forum EditingReplies: 20Last Post: 9th Sep 2008, 22:53 -
Corrupt Frame on avi file
By thankyou in forum RestorationReplies: 1Last Post: 2nd Oct 2007, 20:58
