Hi all,
I have a VHS tape i would like to capture to an mpeg file. Howeven when i connect it up to my pc the file is black and white! My vcr and tv is ntsc playback so it is color on the tv.
Is there anything I can do in regards to this?
My VGA card is the Asus V8460. I tried using virtual dub and asus digital vcr with no luck.
Please help!![]()
Slats
Hi!
The same here! and I do not understand where in PC I can adjust it?
Please, maybe sameone can help us?!
I have P4 with Geoforce_3 + nVidia WDM Video Capture (universal)
Thanks in advance
RGRDS
Skeeper -
Make sure your card is capturing in NTSC and not PAL. Some of the WDM universal drivers out there will lock you into PAL mode ( as noted by the 25 fps, and no option for 29.97 fps ). If your VCR has Macrovision, and you capture card doesn't like it, you will get garbage.
To Be, Or, Not To Be, That, Is The Gazorgan Plan -
@Gazorgan!
Thanks for quick reply!
>( as noted by the 25 fps, and no option for 29.97 fps ).<
Why NO OPTION for 29.97 fps that is correct or?, but anyway for my hardware NO WORK, no with 25 fps or 29.97 fps!
Maybe is really that my VCR has Macrovision?!, I dont know!
Actually how its possible find out if by mine VCR in fact Macrovision?
and if there is really problem with Macro, how I can to solve it?
best rgrds
Skeeper
able to capure with firewire with Windows Movie maker but not with Pinnacle
By irtirat in forum Capturing and VCRReplies: 4Last Post: 17th Apr 2009, 15:47 -
PAL & NTSC in the same camcorder
By griffmedia in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 24th Feb 2009, 12:55 -
Portable NTSC & PAL TV?
By Disco Makberto in forum Portable VideoReplies: 12Last Post: 14th Nov 2007, 23:31 -
Capure fro DVD direct or thru AVI
By perfection in forum Newbie / General discussionsReplies: 2Last Post: 3rd Jun 2007, 03:54
