Hi,
I try to rip a SVCD disk using VCDEasy (tried a few versions, including 1.1.4).
In "Tools" section, SVCD Build/Rip, Dissassamble a SVCD disk there are 3 sources to choose: CD Reader, CD Writer, CD Image File. Only CD Image is active, the first two are greyed out. Is it normal? Should I create an image file first? I could do it with Nero, but I'm not sure what reading options are OK for making an image of SVCD disk.
Thanks!
Latet
Here's what you gotta do
open vcdeasy
go to settings
in the vcdeasy part, check the 'enable cdrdao integration' box
(you will need a valid aspi, see http://cdrdao.sourceforge.net/drives.html for details)
restart vcdeasy
go to settings, in the cdrdao part, configure your cd reader
restart vcdeasy again
go to tools
your cd reader should be accessible now
Backing up DVD/Blu-ray to disk, watching movies directly from disk to TV.
By mb312 in forum Newbie / General discussionsReplies: 0Last Post: 11th Feb 2010, 16:35 -
Program Edit greyed out on NEC NDRV-60
By scottee in forum Newbie / General discussionsReplies: 0Last Post: 6th Jan 2010, 12:25 -
AutoGK "start" button is greyed out
By Purno in forum Newbie / General discussionsReplies: 3Last Post: 1st Mar 2008, 05:36 -
"Filters" greyed out in VDubmod
By Captain Satellite in forum Newbie / General discussionsReplies: 5Last Post: 16th Aug 2007, 12:39 -
How to mux three sources, but delay only two?
By hrpatton in forum ffmpegX general discussionReplies: 11Last Post: 11th May 2007, 18:22
