Hi all,
I'm trying to buy some 2x DVD-RW brand-name media for my DRU500A...will these 2 do it?
TDK DVD-RW47S
http://www.pcconnection.com/scripts/productdetail.asp?product_id=258553
Sony DMW47L1:
http://www.pcconnection.com/scripts/productdetail.asp?product_id=275384
I know they'd work with DRU500A according to the media threads...just not sure if they'd burn in 2x.
Thanks!
don't know about those 2 brands because they are to expensive for me but i know that ritek burns at 2x speed and if it does then those should. Ritek is around 85 cents for dvd-r.
Call me stupid, but don't both the links say those RWs are 1x, does that answer your question.
If you are looking for major band, check the Sony Media Compatability list.
http://sony.storagesupport.com/legalagreement.zulu?dlid=dvdrw/mediainfo_na.htm -
I see only "DVD-RW x 1" - that's one disc per product.Originally Posted by Mr Zippy
I have the Sony DVD-RW and they are only burn at 1x(1 hr). If you want speed then use DVD+RW as they burn at 2.4x (30min)
May the force be with you. -
I agree with Mr Zippy, they are 1x (speed)Originally Posted by HyperYagami
I own Sony one.... it is 1xPinnacle Studio 8 and DV home video editing (ver.9 already home) -
I believe that you are talking about -R and he is asking about -RW (ReWritable)Originally Posted by sunmiztresPinnacle Studio 8 and DV home video editing (ver.9 already home)
haali media - use custom media type for h.264
By adom in forum Video ConversionReplies: 0Last Post: 15th Mar 2011, 06:07 -
AccountKiller
By rcvalle in forum MediaReplies: 3Last Post: 13th Dec 2010, 22:05 -
How To Convert DVD Media Made From VHS Media For Sharing Online
By BlazingSpeed in forum Video Streaming DownloadingReplies: 0Last Post: 11th Dec 2010, 14:20 -
No Sound Coming From Media Player or Online Media Players
By Teac23 in forum AudioReplies: 4Last Post: 11th Jul 2010, 07:52 -
DMR-EZ27 records on rewriteable media, but gives U61 error on other media!
By dr-rjp in forum DVD & Blu-ray RecordersReplies: 2Last Post: 11th Jun 2008, 18:58
