  1. Can one rip and write (a DVD9 movie) to a DVD9 with existing hardware/ software (DVR-105 and, DVD ripping tool, and Nero?)
  2. does your burner support dvd9? if so then i believe it can be done but alot of burners don't support dvd9 yet plus the dvd itself is expensive.
    Jan 2003
    That canīt be done.
    Does there even exist DVD9 +-R/RW discs?????
    However there are doublesided DVD R/RW so called DVD10 that should work.
  4. Member dcsos's Avatar
    Jan 2003
    Y No Werk (anagram)
    YOU GUYS are talking about DUAL LAYER DISCS listed below
    THESE ARE TWO BURNABLE SIZE DISCS GLUED TOGETHER
    you cannot do this yourself!
    (its not the DVD-5 format you burn that holds 4.7 or 4.3gig))
    dual layer specs:
    DVD-9 (12 cm, SS/DL) 7.95 gig (8.54 BB), about 4 hours
    DVD-10 (12 cm, DS/SL) 8.74 gig (9.40 BB), about 4.5 hours
    Jan 2003
    A DVD10 is NOT dual layered!!
    DVD9 and DVD18 are dual layered.
    A DVD10 is doublesided.
    All of above and DVD5 are premastered DVDīs.
    You cannot burn a premastered DVD but there exists doublesided
    DVD R/RW that can contain 9.4 GB of data
  6. Member dcsos's Avatar
    Jan 2003
    Y No Werk (anagram)
    thanks for straiteneng me out
    but like we both said..you can't burn a DVD-9
    Jan 2003
    No problem dcsos.
    I should have been more precise and
    not combine DVD10 and DVD R/RW
  8. thanks for the feedback.
    Bottom line: you cannot wite to DVD9 or DVD10 media with existing equipment. (like the current SONY or Pioneer drives)
