  1. Hello .
    I'm currently looking for a PCI video card and i'm wondering if it is worth buying the AIW VE for around $220 can.? If not, can someone suggest some other cards that are capable of capturing video and is also a decent card for gaming?
    Thanks!!! :P
    G2k
  2. I have had 2 ATI cards, I like them, had the AIW 128 Pro, now a TV Wonder, I wanted the s video and composite input that I don't think the VE has. Make sure you have a compatible video card, update the gart drivers,usually on the cd with the video card, install microsoft videocapture update, then DX8.0a then use the registry tool and I have had great results. No conversions, just capture, burn using Nero, and delete.
  3. I had TV Wonder VE and it was realy bad. I had AIW Radeon 7500 and quality was much better. I believe they use different chips. Si if AIW VE is using same chip as TV Wonder VE, don't buy it.
