I was wondering if there is a loss in sound "fullness, quality" when listening to a 5.1 encoded DVD on my 2 PC speakers. Or how is it when listening to a 2.0 sound on a 5.1 system?
I don't want to use 5.1 and 2.0 both when creating a DVD but if there is a loss in quality, then I suppose I just might....
experiment with headac3he a bit
You can extract the 5.1 channel audio to separate channels
Of course you'll loose sg. but I'm not sure that's quality.
Stereo on 5.1 can be played 2 ways: js on the .1 and center. stereo on the left/right pair. Or js on the .1 and stereo on the left/right front.
Movies aren't only for thoose with 5.1 systems. The makers of the movie probably will create the film with that in mindAnyone tired of his old DVD burner? Why put it into the trash? Contact me! :))))
question on speakers with MP3 playing capabilities
By ktnwin in forum Portable VideoReplies: 3Last Post: 10th May 2013, 23:16 -
AC3 Filter volume problem across speakers.
By chrisssj2 in forum AudioReplies: 1Last Post: 24th Feb 2011, 10:36 -
Audio isn't playing out both speakers after turning VHS into a DVD...
By littleBIGworld in forum Newbie / General discussionsReplies: 4Last Post: 19th Feb 2011, 02:44 -
How do I: Record Video, Audio from MIC, AND Audio playing from speakers?
By miimaster2 in forum Newbie / General discussionsReplies: 8Last Post: 11th Feb 2011, 21:51 -
Does 7.1 audio limit the rear speakers and divert to the side speakers?
By yoda313 in forum AudioReplies: 0Last Post: 4th Oct 2009, 10:55
