Using TMPGEnc:
I'm converting a 120 minute movie to CVD (352x480) 2 pass VBR of 2520max/2150average/1200min, high quality noise reduction and sharpen edges. My only problem is it estimates about 55 hours for the conversion.
Am I just expecting too much in too little time? or is this realistic? Should I just abandon the noise reduction and edge sharpening? (average quality DivX 800 meg for 2 hours)
Should I just CBR it at 2520 and burn to 4 cd's? or how about a lower CBR to where it would fit on 3?
Any help would be appreciated. My system stats are as follows.
Athlon XP 1700+, 512 meg Pc133.
Try taking out the filters(noise, sharpen) and see how that works.
if you need filters use avisynth.....
2 cd's at 800 meg each should take a few hours each
I have a PIII and have no problems with time.
Scott -
just figured this out as you posted.. without the filter it'll do the whole movie in 4 hours.. much better.
Thanx.. -
I use the edge sharpening and find it doesn't affect the the time, noise reduction though is another story. Takes way too long, I rarely use it.
"Art is making something out of nothing and selling it." - Frank Zappa -
The noise reduction of TMPGenc is amazing, but is way slow...
An alternative is to clean your source in Vdub during frameserving. With Vdub mod this is really easy now (no more vfapi convert...)
I am searching for the best filter for this, the opinions varies a lot! -
what about using avisynth? you can use filters like fluxsmooth,dust,blockbuster etc and get nice results.
avisynth is OK also.
I prefer VDub, 'cause I can preview what I'm doing. -
i just like to say a little experience i had.
I had a movie that's 2 hour 10 minutes long and i used CBR and it takes 4 CDs
and now i got the same movie and converted again using CCE with 4 pass VBR the result i got was excellent. and it runs about 65minutes on a Single CD. i was really surprised by the end result, hardly any blockiness. you should really not make any movie more than 3CDs.
ffmpegX taking LONG time
By macgurl in forum ffmpegX general discussionReplies: 1Last Post: 23rd Apr 2011, 01:50 -
Editing video in virtualdub taking so long!
By admirer in forum Newbie / General discussionsReplies: 14Last Post: 8th Apr 2010, 14:43 -
MPG Files taking a long time to open.
By Ads79 in forum Software PlayingReplies: 8Last Post: 13th Nov 2009, 10:39 -
Rendering taking too long- How to speed it up? (Sony Vegus movie)
By Entry in forum Newbie / General discussionsReplies: 9Last Post: 18th Aug 2009, 01:47 -
Settings Correct? Taking a Long Time/.avi to DVD
By 5Buffalo in forum ffmpegX general discussionReplies: 3Last Post: 24th Dec 2008, 15:29
