Just a quick question, I have recently downloaded 2 movies in the xvid format. Now I have a apex 500wm that will play these files as is if burnt to a cd. I am first wondering if I should convert these files to another format to increase quality etc., or not? Secondly, if I should just leave these files in this format, how should I burn them (nero)? Thanx.
The number 2 myth on VCDHelp: Converting to increase quality.
You can never convert something and make it better. Sometimes you can convert it and clean it up a little(certain types of noise or nonstandard resolution), but you lose quality anyway.
Audio is the same way, just typically you can't tell. If you take a 128 kbps MP3, filter it, reconvert it to mp3, you will introduce more distortion (but you may have fixed a problem with HUM or ringing).To Be, Or, Not To Be, That, Is The Gazorgan Plan
Xvid.Max conversion
By hawkeye48 in forum Video ConversionReplies: 0Last Post: 26th Jun 2011, 03:48 -
Help with MKV to XviD Conversion
By Chaser250 in forum Video ConversionReplies: 9Last Post: 20th Feb 2011, 04:08 -
DivX/Xvid conversion
By joecass in forum Newbie / General discussionsReplies: 4Last Post: 22nd Apr 2010, 16:23 -
Xvid to DVD conversion
By Meriks in forum Authoring (DVD)Replies: 5Last Post: 5th Apr 2008, 11:43 -
Help with conversion to Xvid
By zovx in forum DVD RippingReplies: 2Last Post: 6th Feb 2008, 16:32
