Hello....
I have sucessfully joined (merged) many of mpeg2 in my lifetime but i do run into this problem now and again....
ERROR: *.mpg is not compatible with other MPEG file.
This is really starting to piss me off, i try everything i know but still no luck. I even try to make both files the same by rencoding the intro to the same specs as the other mpeg, still no luck.![]()
Please help....
There must still be a difference, try loading both half in separately and saving them back out without doing anything to them.
1, select video type from drop down list> Add >, save out another copy.
Do the same with part 2, then try to merge those.
Are there any software that will SIMPLY cut and merge *.mts without re-enco
By skydutch in forum EditingReplies: 1Last Post: 12th Nov 2011, 04:04 -
How to Cut & Merge mini 10 part mini series?
By skorpinok in forum EditingReplies: 5Last Post: 8th Oct 2011, 09:41 -
How can I cut/edit/merge/add some info/add hardsubtitle in one media (DVD)?
By roUndy_sh in forum EditingReplies: 8Last Post: 26th Dec 2010, 17:45 -
Cut and Merge MPEG-2 Files
By flash_49 in forum EditingReplies: 8Last Post: 12th Feb 2010, 10:03 -
How the cut and merge function works on your dvd recorder?
By v1p0n3 in forum DVD & Blu-ray RecordersReplies: 3Last Post: 5th Jan 2010, 05:59
