after i rip a move and use tmpgenc on one disk guide i put the movie on disk it plays fine all the wat through until about 20 min left in the movie and it starts skiping and blocks up any help?
These problems tend to happen from using low quality media. Also there is a thread that is talking about having those exact problems from puting labels on dvds. This could also be your problem. To know whether the problem happened during encoding or burning you should check the file on your computer before you burn it.
SD movie to bd disk
By Regor21 in forum Authoring (Blu-ray)Replies: 2Last Post: 25th May 2011, 03:43 -
Combining data files with a DVD movie on the same disk
By j_p in forum Authoring (DVD)Replies: 6Last Post: 26th Jun 2008, 02:52 -
Adding a menu to a dual-movie disk
By WHeisenberg in forum Authoring (DVD)Replies: 2Last Post: 3rd Apr 2008, 15:29 -
fitting more than one movie on a dvd
By LaLuna in forum Newbie / General discussionsReplies: 4Last Post: 21st Jan 2008, 19:15 -
Encore DVD 2.0 Movie location on disk
By thesixuk in forum Authoring (DVD)Replies: 2Last Post: 7th Aug 2007, 12:52
