can someone help i want to convert vcd to dvd on OSX
please help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!![]()
This is how it can be done.. but I'd like a quicker way if anyone knows..
1. Use VCD Copy X 1.1 to copy the DAT files to my hard drive
2. Use VCD Gear X 1.0 to convert the DAT files to MPGs
my mpegs are mpeg-1 NTSC video. 320x240 or 351x240 at 29.97fps
audio is mpeg-1, layer 2(mp2) with bitrate = 224kbit/s and sampling frequency = 44.1 khz
3. Use BBDemux to demultiplex the mpeg into separate video (m1v) and audio - but don't bother with the audio
4. Use ffmpegX to make an mp2 but re-sample the sampling frequency from 44.1 khz to 48khz.
-Set the preset to 'low bitrate DVD' but change the Video Codec to "passthrough(ffmpeg)" and UNcheck the encode video box.
UNcheck the Author as DVD box in the tools tab.
5. now you should have an m1v file and an mp2 file.
Use MPEGinfo to see that the audio is at 48khz (this is important)
6a. You could use Sizzle from here to author a dvd disc image
or
6b. Use ffmeg X to re-multiplex them back into a new mpeg. Be sure to choose "Mux as... DVD"
The resulting mpg won't play in quicktime but it will in VLC- check for sync issues or freezing - sorry those might not be the correct terms.
7. If its good, use MissingMpegTools to Author your DVD folders
8. Burn the AUDIO_TS and VIDEO_TS files to DVD in Toast.
I've also tried to get ffmpeg to make the new mpeg in one step - using passthrough(ffmpeg) video codec, with encode video on. This is faster by far, but the resulting mpg is not correct (I forget why right now).
If someone can give me a faster way, I'd be pleased to know. Thanks
Ripping a Region 2 DVD on a Mac Book Pro with Mac The Ripper
By Jess021 in forum MacReplies: 7Last Post: 17th Nov 2011, 05:04 -
Capturing VHS to Mac via Panasonic AG-1980 and ATI 650 USB Mac
By Stu187 in forum Capturing and VCRReplies: 3Last Post: 15th Aug 2010, 05:45 -
Formate/specs for video file which play smoothly Across G4 MAC/ PC /MAC PRO
By krijes in forum EditingReplies: 1Last Post: 2nd Apr 2010, 05:18 -
im new to mac... is there a mac program that does what tmpgenc dvd author 4
By ochsfamily in forum MacReplies: 0Last Post: 12th Dec 2009, 22:13
