Read The Fuc..ng Manual(sorry but it's all covered there). And Dazzle's is a printed one!
I'm using 4.25 now. All versions do it though.
In movie star, there are two tabs on the left (little bumbs) select the second/bottom one. This allows you to import clips, and keeps a tally of what you've recorded. Once it expands, you'll see a tab labled effects. Here is where you can do custom scrolling titles, transitions etc......
Notice the two bumbs along the bottom? The one just below the stop button opens the editor. Drag two clips on the time line, at the split drag an effect there. You can resize the transition to last a second, minute, what ever you want.
If you have one long clip, you can hit the split button, then add you transition there.
That should get you started, for more help RTFM![]()
Results 31 to 34 of 34
joeAgain------, If this is true than it would be great. Please don't forget to post back result.Originally Posted by disturbed1Pinnacle Studio 8 and DV home video editing (ver.9 already home)
Oky-doky, Donpedro and guys.
Spawn just told me that MovieStar has some transitions that I can add, but they aren't very cool. I'll check those and look at MediaStudio. (it does let me import Mpeg-2 files, right?)....seems like I tried an older version that didn't accept them.
Does it now?
transitions hard to add on multiple clips in premiere
By codemaster in forum EditingReplies: 11Last Post: 7th Jan 2011, 12:34 -
Question how to add subtitles with TMPGEnc DVD Author 3
By jimdagys in forum SubtitleReplies: 1Last Post: 5th May 2008, 18:24 -
Problems when I try to add subtles in my video on TMPG DVD Author 3
By ihmcjacky in forum Authoring (DVD)Replies: 4Last Post: 22nd Mar 2008, 02:24 -
Best program to add clips together?
By Soccerman77 in forum Video ConversionReplies: 3Last Post: 13th Oct 2007, 03:47 -
Ulead Videostudio Transitions - How to Add?
By markannab in forum EditingReplies: 1Last Post: 28th May 2007, 13:54
