Hi , first of all i ripped of an episode of "Record of Lodoss war" from a dvd following the instuction of the guide. I finally created a mpeg of the episode successfully. Then i ripped of from the dvd the subtitles using subrip. I followed the instructions of using the VirtualDub , i put the filter i chosed the subtitles and when i clicked start frameserving i chose where to save and then the window that appears doesn't do anything , after 10 min 0 frames were served.
Do you know how to solve the problem or do you another way of adding subtitles to a video. ( the mpeg i will use it then to make a vcd)
Thanks!
Results 1 to 1 of 1
Once I put an MKV thru multiAVCHD the subtitles are lost
By mahogany in forum SubtitleReplies: 4Last Post: 8th Oct 2011, 14:49 -
how to put subtitles under the vedio !
By ary190ary in forum SubtitleReplies: 4Last Post: 31st May 2010, 17:48 -
How to put subtitles in a m2ts file ?
By sn0wer in forum MacReplies: 4Last Post: 18th Mar 2010, 10:52 -
How do I get subtitles from a DVD to put into an XVid?
By Emanef in forum SubtitleReplies: 7Last Post: 23rd Jul 2008, 12:45 -
How to put subtitles to a mkv file
By donpato in forum SubtitleReplies: 2Last Post: 6th Apr 2008, 16:17
